converting
converting
Postby ACA0759 » Fri May 03, 2019 5:18 am
Is there a "simple" utility that converts FS2004 aircraft to FSX, FSX Steam aircraft?
ACA0759
Re: converting
Postby EAL0739 » Fri May 03, 2019 9:13 am
ACA0759 wrote:Is there a "simple" utility that converts FS2004 aircraft to FSX, FSX Steam aircraft?
You do not need that. You just need to change panels and presto that will work. In other words, you need to change from FS2004 compatible panels to FSX compatible panels. That should work for 90 percent of aircrafts. In matter of fact, 85 percent of my aircraft in my FSX Deluxe with SP1 and SP2 are actually from FS2004.
What FS2004 aircraft are you planning to use in FSX?
Regards,
EAL0739 Aharon Dayan
EAL0739
Re: converting
Postby ACA0759 » Fri May 03, 2019 10:07 am
Wow....so simple. Thanks so much - I will try it.
ACA0759
Users browsing this forum: No registered users and 1 guest
